Optimising Settings for Gaming
AWB70
Hi all, been a while! Just wondering, bought a Samsung TV which came with Xbox cloud gaming pre-installed. Being an old skool gamer from back in the day thought I'd give it a whirl. I wasn't expecting anything miraculous to be fair but sometimes it was quite good. Problem is it is running on wifi and when everyone is in streaming TV in other rooms it becomes unplayable.
 I notice there's 2.4 ghz and 5ghz channels on my hub 2 router which got me thinking, could I set the rest of the house to 2.4ghz and have the one tv on 5ghz? I noticed when reading the bumf hub 2 doesn't split wifi bands although my hub 1 does (See attached) so maybe that isn't even an option.
Are there any other settings I could tinker with in the router that would give the TV precedence or optimise it for gaming?
According to Xbox there's a setting to switch the tv for gaming mode but I can't appear to find that on mine, the only option I can find appears to be if something is connected through the HDMI.
Tv's in a small extension I recently built, how I wish I'd run cat6 to it now instead of a coax I didn't even need! Running cat no longer an option.
Thank you.
7 REPLIES 7
outcast
Aspiring Champion
Fixes: 19
Re: Optimising Settings for Gaming
@AWB70 wrote:
... how I wish I'd run cat6 to it now instead of a coax I didn't even need! Running cat no longer an option.
LOL !  🤣
Does the other end of the coax go anywhere near something else with an ethernet port ?
If you Google "ethernet over coax"
you'll find articles like this - "How to convert your home's old TV cable into powerful Ethernet lines"
and cheap adaptors on Amazon, e.g. "Coax to Ethernet Adapter" amongst many !
I have no experience of trying that, but it looks like it should work well enough for what you want.
AWB70
Unfortunately not mate although ethernet powerlines could be an option. I rewired the extension on a new circuit which ended with a double socket one the end of the ring main next to the router. Used them back in the day and the speeds were never anywhere near claimed. Not sure if they have moved on these days or would even be an improvement?
Fixes: 118
@AWB70
Given you know where the coax cable runs is there any possibility to use it to "pull through" an ethernet cable. Given the likley usage you probably get away with Cat 5e which is more flexible than Cat 6.
Modern power adapters can cross modern power circuits. Other's might be able to recommend suitable ones for you to have a look at.
AWB70
Thanks for the input Brian, unfortunately, probably not possible again. The coax runs from extension , through kitchen ceiling and ends in an airing cupboard where I've installed a 4way splitter. The router is nowhere near either location which would mean having to get another coax down to the router by the front door. it's is also well and truly clipped to joists.
I'm assuming from the lack of responses regarding the wifi that there aren't many tweaking options within the router?
Perhaps I should looking towards the powerline adapters again and give them a re-visit.
Fixes: 585
If it helps, I have a pair of 1000AV plugs I use occasionally.. On the same electrical circuit they will achieve around 150Mb,. On a different circuit but controlled by the same RCD , they give around 50Mb. On circuits via different RCDs they will only get around 20Mb
AWB70
Thanks buddy, I'll start having a look at them. I think I may have some AV600 kicking about somewhere, will be quite old and I guess tech will have moved on a lot. I see there are some that cancel out noise.
Luckily the wiring is on the same RCD and same ring main. When I built the extension I also rewired the kitchen so the kitchen and extension is on a separate ring to the rest of the house. When I did it I realised I'd made the last leg of the main a touch too short to reach the consumer unit 😓 Sorted it out by putting a double socket under the consumer which handily is where the router is.
Having a look into my wifi settings I notice it also wants a good clear out! Leftover devices I no longer have and a myriad of people's mobiles that have visited my house. I start by clearing all them out I think first.
Worth trying the AV600's and see how I get on with them, if no better I'll look into better versions, does the plusnet router have an ethernet port that is faster than the others? I think I only have my Hive heating plugged into it at the moment.
It might all be in in vain tbh, Xbox cloud gaming is really still in beta so all my changes might not make much of a difference.
Worth a try though.
Fixes: 585
No, it has 3  LAN ports, you cant use port 4(WAN),  all are gigabit
