New Router
Toby1971
Fixes: 4
New Router
I am expecting a new PN 2 Router  replacing BT 6 Router. can I login with my existing details and SSD on setup to save changing all my existing details to equipment connected to the BT router
12 REPLIES 12
SpendLessTime
Fixes: 86
Re: New Router
There is a nice thread with all the information in the first post about using a BT Smarthub 6 on Plusnet at https://community.plus.net/t5/My-Router/Using-the-BT-Smarthub-6-on-a-Plusnet-Account/m-p/1587673#M85...
Re: New Router
@SpendLessTime wrote:
There is a nice thread with all the information in the first post about using a BT Smarthub 6 on Plusnet ...
I think @Toby1971  is going from Smarthub 6 to Plusnet Hub 2
Re: New Router
@Toby1971 in answer to
Do you mean SSID? Then yes you can.
Warning, you can not split 2.4GHz and 5GHz wireless names, the Hub Two only has three LAN ports, the fourth port is for a WAN connection.
Toby1971
Fixes: 4
Re: New Router
Thank you for your reply.,  however I wll be changing to the PN Hub 2,from my BT Router as part of connection upgrade. All i want to now is can i i plug PN 2 using existing details, or do I have to start from scratch.
Re: New Router
The Hub Two should auto setup on first connection as it it should be on TR069 system.
If you want to keep your current wireless name to your choice go to http://192.168.1.254   Advanced Setting >Wireless
Any port forwarding rules you may have will also need adding by you.
SpendLessTime
Fixes: 86
Re: New Router
@Anonymous Misread that as I was thinking he wanted to use the BT Hub with Plusnet. Ops.
Toby1971
Fixes: 4
Re: New Router
Thanks for all the replies, installed new router, no problem, just awaiting now for the speed increase
Thanks again
RealAleMadrid
Fixes: 68
Re: New Router
@Toby1971  Have I missed something, why are you expecting a speed increase? If you have changed product to Fibre Extra the speed should increase as soon as the upgrade happens. Maybe it hasn't yet.😊
Toby1971
Fixes: 4
Re: New Router
Sorry, I should  have added that i have upgraded to fibre plus and still awaiting for this to be activated
Fixes: 1,662
Re: New Router
Apologies for the delayed staff response but just to confirm your upgrade should complete on the 14th September.
Let me know if there's anything else you'd need help with.
Toby1971
Fixes: 4
Re: New Router
Thanks for your input, was upgraded this am
Fixes: 1,662
Re: New Router
Cool. No worries, let me know if there's anything else you'd need help with
