New Router
Thomasjc174
New Router
Hi everyone coming back to plusnet after changing to talk talk for last 2 years. What Routers are people using these days? I’m guessing I’m getting the hub 2 but just wondering what other routers you are using
6 REPLIES 6
Fixes: 480
Re: New Router
@Thomasjc174  Welcome to the forum,
 It’s the old Hub 1 for ADSL or the new Hub 2, which is based on a a BT Smarthub 2 for fibre,
Thomasjc174
Re: New Router
I should of said for fibre. Anyone using a non supplied router and if so what one. When I was with plusnet before I was using the ASUS RT N66.
Fixes: 480
Re: New Router
@Thomasjc174
Don’t dismiss the hub 2 without trying it.
Regards other hubs you will probably get as many different devices as replies.
Thomasjc174
Re: New Router
I will be trying the supplied router just looking into other options as I have a area in the house which is a bit hit and miss for WiFi so we shall see how it performs
thomasjc1
Re: New Router
Well blimey didn’t realise I could use my old username back from 2013 when was with plusnet
198kHz
Fixes: 42
Re: New Router
🎵  You can check out any time you like but you can never leave...  😉
BT technician (Retired)
