Plusnet Hub Two question
Timalay
It may seem like a really daft question, but will the BT Whole Home Wi-Fi discs work with the Hub Two?
5 REPLIES 5
Fixes: 479
Re: Plusnet Hub Two question
@Timalay
In a word, yes. It will work with all ISPs equipment.
Timalay
Thanks, I wasn't sure how closed in it was to BT own equipment/network.
bobpullen
Fixes: 330
Whole Home Wi-Fi discs will work (i.e. the white ones); Complete Wi-Fi discs will not though (the black ones).
Edit: as @Baldrick1 has rightfully pointed out, the latest iteration of the BT Whole Home discs are in fact also black. These will work too.
Fixes: 479
@bobpullen
For info the latest WiFi 6 versions are black:  https://shop.bt.com/products/bt-whole-home-wi-fi-6---three-discs-105601-GD38.html?utm_source=google&...
I was going on the 'Whole Home WiFi' description.
bobpullen
Fixes: 330
@Baldrick1 well pointed out, thanks.
I've edited my post.
