New Router setup
MikeAC
New Router setup
I have received a new Plusnet hub 2 to replace my existing hub 1. Is it possible to setup the new hub with my existing SSID and password to prevent having to set up all my connected devices (over 20) connected to 2.4, 5.0 MHz. Or can I copy those shown in the My Home Connections of the router Web page.
2 REPLIES 2
Fixes: 118
Re: New Router setup
@MikeAC
Login to the Hub2 managment page, then look at Advanced Settings.
You can change the SSID and password here.
@MikeAC
You'll find you can not split the 2.4 and 5 GHz Wireless names, hope that's not a problem for you.
