Do Plusnet throttle other routers?
Berty
Just swapped to FTTP 900 and I am getting better results on the latest plusnet hub than a Netgear XR1000 V2 which makes me think  Plusnet don;t like you using your own gear. So they throttle it?
Anyone throw any light on this please
Many thanks
5 REPLIES 5
Fixes: 585
Re: Do Plusnet throttle other routers?
I can assure you they don't! I have always used my own router and get the full speed on my FF900 connection.
Is it wired speeds that are affected or wireless ?
bobpullen
Fixes: 330
@Berty - what QoS/prioritisation features do you have enabled, if any? Tried with them switched off?
Fixes: 585
@Berty this might be worth reading https://community.netgear.com/discussions/en-home-nighthawk-pro-gaming-routers/xr-1000-slow-speeds-i...
Berty
Thanks for the input.
Connection is wired.
Whilst testing was only one PC connected.
Slower download and higher ping on the XR rather than the plusnet hub,
Read so much and tried so many suggestions nothing worked
Reset XR and reconfigured it.
Berty
Given up on the XR1000 bought a R3 to try.
