New Hub Two delivered but i need to know how to set into modem mode only
- My Router
- New Hub Two delivered but i need to know how to se...
23-10-2024 10:48 AM
Hi Guys
I have been on Plusnet for years and my setup has always been i use a Huawei EchoLife HG612 3B FTTC VDSL MODEM G.INP NTE BT openreach ta act as a modem only. This then feeds into a my Opensence router on its own unit.
Can i replace my Huawei EchoLife HG612 with the Hub 2 to act as a modem only? The Huawei EchoLife HG612 only supports download up to 100mb, so no use for a 900mb download.
If possible how do i accomplish it bit of a noob with Hub 2 units.
Re: New Hub Two delivered but i need to know how to set into modem mode only
23-10-2024 10:54 AM - edited 23-10-2024 10:54 AM
From the home page http://192.168.1.254 navigate to >Advanced settings >Broadband
The 'bridging Mode' switch is at the bottom of the page, use LAN 1,2 or 3 for your router connection
23-10-2024 10:55 AM
@OsoPolar You do not need a modem with Full Fibre. The ONT performs that function, so you just plug the Opensense kit into the ONT and set up the PPOE credentials on it.
23-10-2024 10:58 AM
If you are Full Fibre you can ignore my post
Dan
23-10-2024 11:02 AM - edited 23-10-2024 11:04 AM
@OsoPolar as @jab1 suspects, from the above you now have a Full fibre(FTTP) connection , is that correct ?
In which case then as John says, just connect your Opensense kit directly to the ONT. It should need no configuration as since you were using an HG612, the PPPoE credentials must already be in the Opensense router.
The bridge mode on the Hub 2 bridges the DSL port to the WAN port and so is of no use (in fact cannot be used) on an FTTP connection.
23-10-2024 11:07 AM
Forgot about that, @MisterW - oops
23-10-2024 11:11 AM
I am on Fibre 75mb currently being fitted tomorrow 900 mb
23-10-2024 11:14 AM
So, when the ONT is installed, connect your kit direct to the ONT, dispensing with the HG612.
23-10-2024 11:25 AM
A slight correction to the above , its actually bridges the DSL to the LAN ports
23-10-2024 12:22 PM
30-10-2024 2:00 PM
So for clarity i can get rid of the Huawei modem see image and connect direct to the Opnsense unit from ONT ( Optical Network Terminal) unit.
Still waiting for Openreach to turn up having cancelled the appointment 4 times !!!!
30-10-2024 2:15 PM
Yes!. Take the ethernet cable that currently goes from the Opnsense unit to the modem, disconnect it from the modem and connect it to the ONT. Job done! well not quite, switch off the modem, disconnect it from the line and dispose of it...
30-10-2024 2:16 PM - edited 30-10-2024 2:16 PM
If you are having Full Fibre to your property you will get one of these installed
PORT is where you connect the OPNSense WAN connection removed from the Openreach modem LAN1 port,
There should be no need to change your plusnet broadband account details.
30-10-2024 2:54 PM
Thank to all you guys for advice and help i have a static IP with Plusnet i was told told i should be able to keep it as its the same account
30-10-2024 2:56 PM - edited 30-10-2024 3:02 PM
The static IP is associated with the account, so yes it should remain in place after the account upgrade.
@OsoPolar what's the spec for your Opnsense router ? is it going to be capable of handling the 900Mb ?
- My Router
