Netis DL4422V as VDSL2 modem
ph1l
I have aquired a Netis DL4422V Modem/Router but cannot persuade it to connect over VDSL. Has anyone manged this? or have any suggestions?
I have a good Wireless router setup already which is far more capable than the Plusnet Hub 1 and just needs a modem to connect so I hoped to use the DL4422V as a modem/bridge. However, it is currently failing to connect in any mode whatsoever.
Settings I have tried:
WAN Mode: DSL
PTM WAN...
  Enable VLAN
  VLAN ID: 101
  802.1p_Mark: 0
  Channel Mode: PPPoE
IP Protocol: IPv4
PPP Settings
  myname@plusdsl.net
  password: ●●●●●●●●
I would think this should get the DSL connection up but no luck - just keeps cycling through IDLE.L3, ACTIVATING, HANDSHAKING
DSL settings have all the ADSL schemes enabled as well as the VDSL2 profiles. Would this cause trouble?
G.Dmt, T1.413, ADSL2, ADSL2+, VDSL2, AnnexL, AnnexM
VDSL2: 8a, 8b, 8c, 8d, 12a, 12b, 17a, 30a
Bitswap, SRA
4 REPLIES 4
Mav
Fixes: 510
Re: Netis DL4422V as VDSL2 modem
Moderator's note(s):
Thread moved from Fibre Broadband to My Router.
Forum Moderator and Customer
Fixes: 338
@ph1l  I'd give up on the 4422 if I were you. It's a very old product, theres no manual on the website http://www.netis-systems.com/Suppory/de_details/id/1/de/78.html .
If you want a modem then either get a BT HG612 from ebay or , if you want a cheap ish  new one, then either a Netgear DM200 or a tplink w9970 ( which can easily be set to bridge mode )
ph1l
Thanks,
I've done as you suggest and given up on the DL4422V! It wasn't going to happen unless someone had the magic hint that made it all work.
Fixes: 338
Yes, the lack of information on the internet made it impossible to determine what might be wrong.
