Need a new Router
tedglen2
Need a new Router
Hello, i would like a wifi 6 router for gaming and game streaming. i have a hub 2. can anyone recommenced a router?
7 REPLIES 7
Fixes: 359
Re: Need a new Router
I can't recommend a router - but is the kit you are using, other the router, WiFi6 capable?
MaxSync
Just a thought,  if you are otherwise happy with the Hub-2,  you could upgrade just the WiFi by adding an external "Wireless Access Point".
Examples of WiFi-6 Wireless Access Points can be found here - www.broadbandbuyer.com
Fixes: 105
@tedglen2
For gaming a wired connection is optimal is it cuts out lag and WiFi buffering.
As to WiFi6 the receiving units must be capable in receiving the signal.
As for a router consider a FritzBox 7530AX. I got a 7530 (non WiFi6) for £35 from CEX.
tedglen2
yes, i have a macbook pro with wifi 6 and a VR headset.
mystreet1
Seasoned Pro
Fixes: 7
Have a look at Flint 2
https://amzn.eu/d/amJlKdf
Wait for black Friday
Was a member for years, but moved from PN fttc to fttp from an AltNet. Getting 940Mb up and down. Happy to stay on here and try to help others. 
markhawkin
Aspiring Champion
Fixes: 20
Although I don't have a Flint 2 I think that's a really good suggestion for a gamer & streamer.
There is a Flint 3 but my understanding is that the Flint 2 is the better choice.
If you have full fibre the Flint replaces the Plusnet hub and you take the WAN connection and plug it into the Flint.
If you have broadband over a phone line then the Plusnet Hub 2 has a "modem mode" which you would use.
MaxSync
Here is the manufacturers webpage for the Flint 2 - https://www.gl-inet.com/products/gl-mt6000/
