My Hub One Router Firmware (also) Needs Updating
BusterRaid
Hi!
Similar to this thread:
https://community.plus.net/t5/My-Router/My-Hub-One-Router-Firmware-Needs-Updating/td-p/1868096
We have a Plusnet Hub One router that reports:
Plusnet Hub One | Software version 4.7.5.1.83.8.217.1.1 | Last updated Unknown
As suggested in the above thread and in the thread:
https://community.plus.net/t5/My-Router/Hub-One-5GHz-WiFi-issue/td-p/1696363
… it seems the device cannot be upgraded remotely.
How can we update the firmware?
Thank you.
3 REPLIES 3
Fixes: 388
Re: My Hub One Router Firmware (also) Needs Updating
@BusterRaid In two words - you can't. Has it been out of use for a long time?
bobpullen
Fixes: 331
@jab1 is right - there's no way for us to upgrade the hub.
Keep an eye on your emails 😉
BusterRaid
@jab1 - Yes, it was offline for a long time - It also had a strange incident whereby when it was reset it connected with another users account(!). Plusnet sorted that quickly but I think it might have dropped off the update list or some such. I have mostly used a Draytek since then, though.
@bobpullen - Thanks Bob! An email has, indeed, arrived!
