My Hub One Router Firmware Needs Updating
brisycom
I've been using a BTHomeHub since I signed up to Plusnet (2 Years Ago), however I am now using the PlusNet provided HubOne, however the firmware must be well out of date: Plusnet Hub One | Software version 4.7.5.1.83.8.259 | Last updated Unknown
Kind regards,
8 REPLIES 8
Fixes: 392
Re: My Hub One Router Firmware Needs Updating
I suspect your Hub could have fallen off the management platform after that length of time, but maybe @bobpullen can check for you.
brisycom
Thanks @jab1 I suspected that might be the case, hopefully it can be added back on Smiley
Fixes: 586
I have a feeling that I've read somewhere on the forums that it's not possible to update a Hub 1 if it has firmware earlier than .263. I think that the url for the management platform changed at .263. I'm sure Bob will be along to confirm ( or not ) ...
brisycom
If that's the case will they send me a new one? Lol Being cheaky 🤣🤣🤣
Fixes: 586
@brisycom you should be Ok. I've just found the thread https://community.plus.net/t5/My-Router/Hub-One-5GHz-WiFi-issue/td-p/1696363 and it's only firmware earlier than .259 that can't be updated.
brisycom
Thanks @MisterW Appreciate you taken the trouble to confirm Smiley Thumbs_Up
bobpullen
Fixes: 331
From here: -
NOTE THAT DEVICES RUNNING FIRMWARE EARLIER THAN 4.7.5.1.83.8.259.1.1 CAN NOT BE REMOTELY UPGRADED AND CUSTOMERS WILL NEED TO CONTACT SUPPORT FOR A SOLUTION IF THEY REQUIRE A HUB WITH THE LATEST UPDATES.
@brisycom - keep an eye on your email 😉
brisycom
@bobpullen You are a legend, really appreciate you doing this for me.
This is ecactly why 2 years on, I'm still here and going nowhere.
Kindest regards,
