Moving from 2704N to Hub One
DortonDoug
I received a Hub One router as part of my recent broadband renewal.  The existing 2704N works fine.  When I disconnect the 2704N and connect the Hub One the lights first go green, then blue, then it flashes orange and nothing further happens.  I have tried all the basics, including resets and connecting it directly to the incoming phone line port.
52 REPLIES 52
Fixes: 388
Re: Moving from 2704N to Hub One
@DortonDoug What username is showing on the Hub1?
Fixes: 1,665
This may be a bit basic, but just to double check is the cable from the telephone socket going into the grey DSL port on the back of the router? And there’s nothing plugged into the red WAN port?
Fixes: 388
Good point, @Gandalf , although if the OP sets the Hub1, connection-wise, exactly as they had the 2704N, I'm still suspecting a 'username' issue. Smiley
Fixes: 1,665
A flashing orange light means the router’s not in sync to the line so that would need to be steady before the router tries to authenticate with the username.
Also the username should auto-populate anyway via the hardware management system.
(I’m not in the office tonight to check)
Fixes: 388
Ah, OK @Gandalf - didn't think of that, should have referred to my 'lights list' before posting. Embarrassed
The username should auto-populate, but we have seen instances where it doesn't. Anyway, as the OP disappeared as soon as they had posted the query, we shall have to wait and see if they return.
DortonDoug
Definitely the right cable in the right slot!  (But thanks for the thought.)  And I've tried a second DSL cable.
Fixes: 388
As @Gandalf has pointed out, for some reason, your Hub1 is not authenticating with the management platform. No doubt he, or another Help Team member will investigate tomorrow.
DortonDoug
When I checked the username on the Hub One it was still showing the default.  I updated it to the one showing on the 2704N, with my password.  No change in the lights.
If it's a data refresh issue, I might try leaving the Hib One plugged in overnight and see what happens.  (We have a limited service due to being copper line dependent and a being a long way from the exchange.)
Fixes: 388
Leaving it plugged in overnight won't hurt, but it might not achieve much. The fact that it was showing the default username suggests to me that it was not properly allocated to your account before leaving the warehouse, so it will probably need manual intervention to properly authenticate.
DortonDoug
You were right, John.  Left the router set up all night.  I came down this morning and it was still flashing orange!
Fixes: 388
Sorry, Doug, but I did warn you. As I said, one of the Help Team should pick this up fairly soon and sort it for you - but they are apparently quite busy over on Twitface, so be patient. Smiley
@DortonDoug
See above.
If its just the long LED flashing then the Hub One is failing to detect the PlusNet network, to me it suggests the Hub One supplied is defective.
Fixes: 1,665
This won't be an authentication problem, if the orange light is flashing. For some reason the hub won't be establishing a DSL connection / sync to the exchange. This has got to happen first before it authenticates to Plusnet.
@DortonDoug, I've ordered you a replacement Hub One which you should receive either tomorrow or early next week. Smiley
Let me know how it goes once you've got it.
DortonDoug
Thanks, Dan.  Only the long LED is flashing orange, with no other LEDs showing.  My guess was the router, given the 2704N works fine.  Felt it was best to check for other options first!
