Moving back to Plus Net
rooky
I am moving back to plus net and getting the Full 900 as had enough with sky and they wanted a lot more from me and not a good services.
How do I form a mesh internet with plus net pls as I had Whole Home with sky that did work
What the best way forward with plus net pls
9 REPLIES 9
rooky
Helo
I have signed up for 900 fibre I assume the pulse net router they send won't get the full benefit of the speed.  So what do you guys suggest me to buy please
Fixes: 387
Re: Helo
@rooky The Hub2 which you will get has 1Gb ports, so in theory, it will deliver the full 900Mb, but, like any router, it depends on a number of factors.
Hardware isn't my strong-point, so I'll leave it to others to explain in more detail.
spile
Re: Moving back to Plus Net
Just get a wireless point and add it to your existing router.
rooky
If I got a new router myself I wouldn’t need use Plusnet
Like if I bough a orbi can connect to the box on wall ?
Fixes: 387
@rooky Yes - as you would the Hub2, and then enter your username and account password.
markhawkin
Champion
Fixes: 22
Re: Helo
@rooky
There isn't a simple answer to getting "the full 900Mb/s" over WiFi.
Firstly you need good (and modern) devices and secondly a good router or mesh system.
There tends to be a fairly strong correlation between cost and quality for mesh systems and the cheap mesh system that everyone is satisfied with doesn't seem to exist.
Start off with the supplied Plusnet hub then see where you go from there.
rooky
Re: Helo
Thinking of getting the orbi a few places saying they good
rooky
What comes after user name @whet?
Fixes: 387
The format is '[email protected]'
