Modem only advice
Stoocoo
Modem only advice
apologies if this has been covered (I am new to this forum) but couldn't find up to date topic.
Our Plusnet internet has been rubbish recently, we are in Cumbria - it is flakey here anyway - but recently it has been dreadful. Plusnet are offering a new contract that would include their latest router. However I need a more drastic solution to living in a house with 4 foot thick stone walls around every room that render WiFi inoperative (hence the mesh).
So - I purchased a TPLink AX1800 Deco x20 whole home mesh system. As the older models of this had a modem system built in - I assumed this would too - I was wrong.
My question is:
Do I take out the new contract with an upgraded plusnet router/modem thrown in, switch off the WiFi and link to the Deco
OR
Do I source a modem only - and if so - which one should I try?
Kind regards
Stoocoo
13 REPLIES 13
Strat
Fixes: 565
Re: Modem only advice
Moderators Note
This topic has been moved from ADSL Broadband to My Router.
TeeGee
Seasoned Pro
My logic tells me that you are going to have the same problem whoever your ISP is so taking out a new contract and getting the latest router would seem to be a good start. It will cost you postage but cheaper than a new modem.  A number of people recommend the BT HG612 from Ebay at around £15.
Welcome to the Community. The real experts will, I am sure, be along soon!
Mustrum
Fixes: 81
I see to recall the Hub 2 can be set to modem mode, which would solve your issues..
Fixes: 251
Are you sure that your problem is WiFi related and not uplink related?  If the mesh will not work through your 4 foot walls, then changing the router is not going to help.
What might help is a different network technology, such as dLan which use the electric ring main to form a wired network.  For example look up the Devolo product range.
Stoocoo
Thank you
Stoocoo
Thank you TeeGee
Good advice! - I have negotiated a new contract and will be receiving a new router shortly.
Thank you for your helpful comment!
Meanwhile - I have a TD!
Who'd a thunkit!
Stoocoo
Mustrum and Townman
Thank you for your helpful comments and suggestions.
I'll try the new router - which should help with download speeds and possibly stop the dropping out of ISP service.
The mesh system is still in it's box and I knew there was something up with the modem part of the Plusnet router/modem.
I have tried Devolo units and TP-Link units - many of them - even linked with LAN cables - but as the property has three separate ring mains circuits they do not work reliably.
So next step was to try mesh - I ordered the mesh system thinking that this would replace my Plusnet router/modem - but no! I still need a modem/router - so I will switch off the router WiFi and rely on the mesh WiFi.
Thank you all for responding to my post - have a guid new year!
TeeGee
Seasoned Pro
Who'd a thunkit!
[Off topic!]  That is awesome! Why not post a pic of it as your avatar?
I am BRG with envy!
Fixes: 480
To get good synchronised wireless in all areas you should use the mesh units with a hard wired Ethernet backhaul.  See https://www.tp-link.com/uk/support/faq/1794/.  This might be problematic with your walls but if there are no alternative cable routes are they really 4 feet thick? Screwfix sell 1m long masonry drills.
Stoocoo
Thank you for your suggestion Baldrick - I will have a look.
and yes - the walls really are 4' thick!! its an old Cumbrian Long House!
Champnet
Fixes: 21
Could you feed a flat ethernet cable under carpets & doors ?
Stoocoo
Enjoy the New Year!
Stoocoo
Thanks Champnet
It may come to that!
