Modem mode
Pedro78
Re: Modem mode
@RealAleMadrid, ok NOT the WAN port. Got it, thanks.
@MisterW  To enter those details, I need a DSL router, don't I?
bobpullen
Fixes: 330
Re: Modem mode
No. The only thing that needs to have DSL capability is the modem (in this case, the Hub Two in bridge mode). The router behind it is irrelevant as it isn't responsible for establishing the DSL link with the local cabinet.
Why not take a look at the Asus WAN settings when you get a minute? Fairly certain you'll find an option for a PPPoE connection that has fields for entering a username and password.
RealAleMadrid
Fixes: 68
Re: Modem mode
@Pedro78  This thread seems to be going round in circles.
Look at section 4.3 WAN in this document Asus RT-AC59U User Guide
Wan Connection Type:  PPPoE
Authentication Drop down menu: One of the options will be username and password
That's all it needs.
Pedro78
Re: Modem mode
@bobpullen
@RealAleMadrid
Thanks for your patience!
I thought PPPoE settings only existed on DSL modems, obviously I was wrong. Forgive me, been on configurationless (is that even a word?) Virgin for years!
At work ATM, will check as soon as I'm home.
Thanks again!
Pedro78
Re: Modem mode
Ok there's the settings! ,as well as the user/pass ect, there's a zillion other things, do I just leave them blank?
Fixes: 585
Re: Modem mode
They're fine left at the defaults, just enter the username & password
Pedro78
Re: Modem mode
Great, will try it after work. Thanks
Pedro78
Re: Modem mode
Couldn't get it working. No internet connection , I probably missed something. I'm just going to buy a DSL router I think.
Thanks anyway guys.
RealAleMadrid
Fixes: 68
Re: Modem mode
@Pedro78  Don't give up, the equipment you have will work. Any clues as to what's wrong? Error messages etc.
Pedro78
Re: Modem mode
That's the thing, no error messages...I've just realized though, the lights stayed blue AFTER I'd put it into bridge mode, according to PN's help page, they're meant to turn pink right?.
But anyways I put my username & pass into the correct fields and saved settings, people in this thread have said nothing else needs changing so I left everything else be. I plugged my router into port 1 on the Hub 2, nothing, tried port 2, nothing...rebooted everything, nothing. Router was in PPPoE mode I triple checked. As Hub 2 was in bridge, I couldn't access it so I factory reset to get it going again.
RealAleMadrid
Fixes: 68
Re: Modem mode
@Pedro78  It sounds like you didn't get the HUB2 into bridge mode properly, there should definitely be a change of colour from the normal router mode. Some say it's more like purple than pink, I don't know as I've never used any Plusnet routers.
Pedro78
Re: Modem mode
I'll try it again later, i 100% selected bridge mode then clicked saved, it even said "your settings are being saved, please wait" , When I refreshed the page, all the settings had disappeared and just the "Bridge mode" slider was there, set to ON. I'll try it again.
Re: Modem mode
@Pedro78
If you connect a pc with 192.168.1.100 IP Address to a LAN port, the home page should look like this when in bridge mode.
The Hubs Home >Status page "Connection Status" should show as 'Bridge Mode'
HTH
Pedro78
Re: Modem mode
Thank you, I'll check later.
Pedro78
Re: Modem mode
Hi guys, got it working just the way people were saying in this thread! Smiley
Tried bridge mode again, this time went straight in, user and pass in the PPPoE settings in the router and bingo!
Thanks for all your patience.
Ped
