Mobile phones not connecting to Hub2 wifi
Fixes: 374
Re: Mobile phones not connecting to Hub2 wifi
@Dan_the_Van  I admit I didn't see the 'reset button pressed' message, but I only had a quick look, and selected 'DSL' as a search term.  Irrespective of that, there are too many 'DSL down messages for the short period covered in that log. Although the fact that the down SNR seems to be holding is a little strange.
Fixes: 145
@jab1
It would interesting if there has been another overnight resync, hopefully @KenMavor can let use know and answer the questions asked
KenMavor
Out and about at the moment.
Only thing I can connect at present is my MacBook via WiFi. I have 6 security cameras and one WiFi doorbell. And a robot mower. There are WiFi extenders but they are both switched off. TVs via hard wire...still both connected physically but not getting a connection. One is through a power plug the other is direct. There are two other mac books and two iPhones. None of these connect. The robot mower just manages to function but sometimes gets disconnected.
KenMavor
New router arrived and daughter plugged it in.
Everything works fine....mobile phones, TVs. doorbell, security cameras etc.
Suspect that the thunder and lightning of a few weeks back had done something to the internals of the router.
