Mobile phones not connecting to Hub2 wifi
KenMavor
Had thunder and lightning a few days ago when we were away.
Lost all connectivity to the outside world from router.
Reported fault but still getting resets and problems including slow speeds.
Current issue is that no mobile phones can connect to the router via wifi....macbooks, pcs, etc via wifi is fine.  Similar with security cameras - no wifi connection.
Disables security on wifi - ie no password and still nowt.
I think the router has been knackered by the thunder and lightning.
Anything else I can check/test to confirm/deny the issues?
Thanks in advance ladies and gents.
63 REPLIES 63
Fixes: 387
Re: Mobile phones not connecting to Hub2 wifi
@KenMavor I don't know which mobiles you have, but one thing you can try is to turn them off totally, wait a few minutes, and then turn them back on -i.e, reboot them, and then try reconnecting them.
As to your 'slow speeds and resets' - which router do you have? Knowing that could help us in suggesting the best fault-finding options.
KenMavor
Hiya.
Thanks for the quick response.
It is a Plusnet Hub 2.
Downstream sync speed:  7.896 Mbps.  Normally 12-14Mbps
Upstream sync speed: 800 Mbps.     Normally 1.4 to 2.4 MBps
When trying to connect from my phone (Pixel 7) and my wife's Iphone.....
Obtaining IP address.......
Saved....
Saved...
Authentication problem
Weird.  Did report problems two days ago and everything was going well but with slow speeds....probably reduced speed to reduce errors.
This is a new one though.
Fixes: 387
OK Deal with one issue a time I think. Have you totally rebooted the phones as suggested? If so, and the problem still exists, as you have an internet signal, as you clearly have as your other devices still connect, albeit slowly, the issue is with the phones. Unfortunately, I have no experience of the Pixel, so maybe using a search engine to query the issue is a good idea.
KenMavor
Switched off and rebooted all mobiles and router.
Still no joy connecting.
Fixes: 387
Sorry about that - hopefully someone else may have an idea, unless, as I said, you can find an answer online.
Now to your slow speed  - what product are you on, and which router do you have?
KenMavor
Thanks again.
I'm on a 2km copper wire which means I can only get about 12 and 2.
Speeds are currently half that.
BT speed is showing 6.93 down and 0.76 up.
Contract is for
Unlimited Fibre has an average speed of 36Mb download and 9Mb upload.
At peak times, we estimate that you'll get the following speeds on your line:
Download: 8 - 10Mb
Upload: 0.5Mb
Minimum Guaranteed Speed: 10.1Mb.
I am surprised that all the phones (2x iphone and 1 android) are impacted in exactly the same way.
Fixes: 387
OK. I too am surprised that both phones have the same issue, but I'm sorry I missed that one of them was an iPhone, which I do have experience of. On that one, what is currently showing on the settings page on the line for 'Wi-Fi' - i.e. does it show your Hubs identity?
As regards your speed issue, can you please follow the below, and provide the information asked for?
BTW Performance Tester - Over a wired (Ethernet) connection if at all possible, please report the 'ADDITIONAL DIAGNOSTICS'. This test is recommended to be performed with only one device connected.
For the Hub One -
For the Hub Two -
KenMavor
First few details.....
Additional diagnostics.....
Summary of Performance Test
Timestamp
Monday 19 August 2024 | 19:38:35
Ping
38 Ms
Download
6.93 Mbps
Upload
0.70 Mbps
Summary Advanced Test
Your speed test has completed and the results are shown above, however during the test an error occurred while trying to retrieve additional details regarding your service. As a result we are unable to determine if the speed you received during the test is acceptable for your service. Please re-run the test if you require this additional information.
KenMavor
KenMavor
KenMavor
No corded phone available.
Quiet line test was quiet.  No noise on it at all.
Fixes: 387
Ken, thanks for those two bits of info. You are obviously on a long 'final mile' of copper - as you indicated earlier. The Quiet Line test is encouraging - now we just need the rest of the information.
KenMavor
KenMavor
The "additional diagnostics" refuses to load up.  I have done this previously, like a year ago, and it loaded fine and all relevant information was accessible and viewable.
