Missing the red-tipped ethernet cable?
Re: Missing the red-tipped ethernet cable?
@Dan_the_Van
I didn't dispute what @Baldrick1 said at the time, but now you mentioned it, I checked my box: it says the same as yours!
I joined Plusnet about a year ago, so maybe the contracts have changed since Baldrick1 first joined PN?
@Anonymous
I joined free online in 2003, I don't recall that message before
Dan
@Dan_the_Van
I think that it depends on when you received the Hub2, (or had it replaced by Plusnet)?
BT's "rules" changed in December 2019.
Obviously in 2003 you wouldn't have been using a Hub2, so possibly when you re-contracted at some point since then?
Fixes: 480
There’s difference between asking for it back and charging for it if it’s not returned. Have you seen any reference to the implications of failing to send it back?
