Problems connecting with TP-Link ER605
TheJayBee
I know a number of you use the TP-Link ER605 so I'm hoping you can help me please.
I have Full Fibre 145 with a Hub 2.
I am trying to replace the Hub 2 with a TP-Link ER605.  I have connected it all up (including connecting the WAN port to the Openreach ONT).  I am using the Quick Start to set up the PlusNet connection.  The settings I have put in are:
  • Connection Type PPPoE
  • Username [email protected] (where xxxxxx is my PlusNet username)
  • Password xxxxxx (my PlusNet Account Login password)
It fails to connect with the message PPPOE [email protected] failed to connect to the server because authentication failed with the wrong username or password.
I have quadruple checked the username and password (I've even used copy and paste) to confirm they are the same username and password as my PlusNet Account Login.  I can only conclude that the PlusNet network password is different to my account password but how to check?
Any help gratefully received.
BTW, the log messages are:
WAN: PPPoE Discovery phase negotiation succeeded. (AC-MAC=20-e0-9c-df-3a-b7, Session-ID=0x057d)
WAN: LCP negotiation succeeded. (MTU=1492, AUTH=chap)
[48-22-54-CE-4C-70]: PPPOE [email protected] failed to connect to the server because authentication failed with the wrong username or password.
6 REPLIES 6
Fixes: 585
Re: Problems connecting with TP-Link ER605
The username and password are the same as the account ones. You can check the username & password by logging into the member centre here https://www.plus.net/member-centre/login
I use an ER605 and I can assure you it works fine.
I appreciate you've checked the username & password but it really does look like what you are entering into the ER605 isnt correct.
Just to check, what hardware version is your ER605 and what f/w version ?
TheJayBee
ER605 is hardware V2 and the firmware is ER605v2_un_2.1.2_20230210-rel62992_up_2023-02-10_17.32.06.bin
I have manually typed the username and password into my router and PlusNet account login so many times. I have even used a text file with the username and password typed in it and then copy/paste those to my router and to my PlusNet Account login. I don't know what else to do to make sure they are the same! There doesn't seem to be a way to display the Hub 2 network password.
Are there any other PPPoE settings I need to tie check or change.
TheJayBee
I'm going to change my PlusNet Account password, leave it for a few hours and then try again with the new password.
Fixes: 585
That's exactly the same hardware & firmware version as mine.
Sounds like you've done just about everything
There isn't, it would be a security issue if there was.
Make sure you haven't got VLAN enabled.
I've attached picture of my WAN settings for info
I hestitated to suggest that, as Ive seen it go wrong on occasion but if everything else fails, try with a simple pw
TheJayBee
Thank you so much for your help.
So, I changed my PlusNet Account Password and used the new password on the ER605 and it worked!
Somehow, my network password was different to my account password.  A change of account password has got them back in sync.
Fixes: 585
Strange!
Anyway, glad you got it working.
I am pleased with my ER605, had it about 6 months now. It copes fine with my 900/115 FTTP connection.
A colleague got one a month ago , used on a Virgin connection. He noticed that the CPU usage was showing about 30% whereas mine is only about 2%. Traced it to the IP Statistics defaulting to On. Unless you really want to gather stats about traffic to/from every IP it sees, I suggest you either disable it or at least specify an IP range to monitor.
It's configured in Traffic Statistics->IP Statistics
