Mesh installed
brigstowe
Mesh installed
Hi
I've just installed a TP link deco P9 system to help with the amount of wifi going through the house at this time. We have a Plusnet Hub One router/ modem combo. Please can someone tell me if the modem/ router has a feature which will enable me to disable the wifi band so that the Deco is faster as both networks are running at the moment.
2 REPLIES 2
Strat
Fixes: 565
Re: Mesh installed
Moderators Note
This topic has been moved from Fibre Broadband to My Router.
Fixes: 1,466
Re: Mesh installed
Yes you can turn off the wireless on the hub one via the routers interface at http://192.168.1.254
