Manhattan SX Freesat box won't connect to WIFI
RichV
Trivial I know but it bugs me:
Manhattan SX  Freesat box instructions -
 • To receive software updates over the internet, connect the SX to your router using an Ethernet cable. Alternatively, you can connect using Wi-Fi during the initial setup.
The Wifi connect dialogue shows my wireless as available however after entering the Wifi password the message issued is "Can't connect to network - try again". Repeated attempts result in the same.
No supporting messages, any ideas, router of freesat box?
2 REPLIES 2
Mustrum
Fixes: 81
Re: Manhattan SX Freesat box won't connect to WIFI
Which router?
If Hub1 split the WiFi bands and try connecting to the 2.4 SSID.
RichV
Great minds think alike! Thank you, I have done this and was about to update my post when I saw your reply.
All good now.
