Key password
Hassio77
Key password
Hi I lost my wireless key password how can I get it back or change it
3 REPLIES 3
Fixes: 388
Re: Key password
@Hassio77 It should be on either/or the pull out card/plastic card supplied with the Hub, or on a sticker on the Hub.
adamwalker
Fixes: 223
Re: Key password
In case you changed the wireless key from the default on one of our routers you can change it back with a factory reset:
https://www.plus.net/help/broadband/router-user-guides/#:~:text=Use%20a%20paper%20clip%2C%20pen,now%....
 Adam Walker
Strat
Fixes: 565
Re: Key password
Moderators Note
This topic has been moved from Broadband to My Router.
