Is it just me...
FIXED- Subscribe to RSS Feed
- My Router
- Is it just me...
03-03-2020 5:00 PM
...or the Plusnet Routers really ugly?
I mean white with pink writing looks OK on a web page, but in amongst all my black/metallic computer gear it looks really out of place and I suspect it will get grubby-looking too, based on past experience.
Fixed! Go to the fix.
Re: Is it just me...
03-03-2020 6:01 PM
Moderators Note
This topic has been moved from Fibre to My Router
03-03-2020 9:18 PM
Yes it’s ugly.
Very little money will buy you a BT Smarthub 6 from an auction site such as EBay. They are black and have better performance.
Setting instructions are here. https://community.plus.net/t5/My-Router/Using-the-BT-Smarthub-6-on-a-Plusnet-Account/m-p/1587673#M85...
06-03-2020 12:39 PM
It looks bad
Other people think it works bad
Plusnet says it may not be fit for purpose. That is plusnet says it's bad.
It's bad.
07-03-2020 11:23 AM
Thanks guys, so the answer is to use one of my old routers and change the settings - I have a BT one that is two years old (which was better than my current, NowTV one), so will probably use that.
07-03-2020 11:43 AM
If you have a two year old BT router it's probably a Smarthub 6. For information the Plusnet Hub One is an even older BT Home Hub 5A repackaged in an ugly case with tweeked and flaky Plusnet firmware installed.
A couple of things to watch when installing a BT branded hub.
Do not use a special character in your Plusnet account password. Plusnet tell you to use one but this can be ignored.
Do not plug the DSL cable in until after you have entered your Plusnet credentials, as instructed in the above link.
07-03-2020 12:28 PM
Thanks. Will give this a go when everything arrives. Changeover date is set for the 18th.
07-03-2020 12:33 PM
Just shout if you have any problems.
