Hub one updates...
- My Router
- Hub one updates...
Hub one updates...
08-08-2018 11:54 PM
Hi
How do I get my Hub One to update?
1. Product name: Plusnet Hub
2. Serial number: +081441+NQ54603580
3. Firmware version: Software version 4.7.5.1.83.8.217 Last updated Unknown
4. Board version: Plusnet Hub One
Thanks in advance
Thanks in advance
Message 1 of 2
(272 Views)
1 REPLY 1
Re: Hub one updates...
09-08-2018 1:21 PM
Hi @Opal
If you follow the steps below it should force the Hub One to update its firmware.
1). Turn off the router using the power button on the back of the router.
2). Insert a pin (or similar) into the reset hole that is next to the power button whilst the router is turned off.
3). Turn on the router keeping the pin in the hole.
4). Keep the pin in the hole for ten seconds and then release.
5). Allow the router to reset.
Let us now how you get on.
Best wishes,
Dave
Message 2 of 2
(234 Views)
