Hub one WAN port
Jovin123
Hub one WAN port
Hi All
Can someone confirm for me that the WAN port on the Hub One is RJ45 and not RJ11? I am considering changing to fibre however my current cable (which runs under the floor) from microfilter to router is Cat5e with RJ11 plug. Would an adapter from RJ11 to 45 work? Also is the microfilter needed for the VDSL2 modem different to the ADSL type?
Thanks in advance
5 REPLIES 5
Mustrum
Fixes: 77
Re: Hub one WAN port
You only need the RJ45 WAN port if you are using an external modem, if you upgrade you will be connected to the DSL, RJ11 port.
Jovin123
Thanks a lot, in some specs I was looking at there was no mention of the RJ11 DSL port only the RJ45 WAN hence my confusion.
Mav
Fixes: 515
Moderator's note by Mike (Mav)
Changed the fix to Mustrum as per message #2
Forum Moderator and Customer
Jovin123
Thinking about this again can I just confirm that the cable currently going to my adsl router is suitable for the hub one ie altho it is RJ11 is it wired the same?
Mustrum
Fixes: 77
They should be the same, although you will get a new one with a Hub 1.
