Hub Two settings bug
- My Router
- Hub Two settings bug
13-10-2022 3:05 PM
Found a bug in the My Devices section of the UI.
If you change the icon for one device, save & go back, when you select another device and, for example, change its device name, when you save & go back you discover that the icon has changed to the one that you set for the previous device. You then have to select the second device again and change its icon back to what it was.
Message 1 of 2
(861 Views)
1 REPLY 1
Re: Hub Two settings bug
13-10-2022 4:17 PM - edited 13-10-2022 5:28 PM
Message 2 of 2
(835 Views)
