Hub Two settings bug
Talldave
Found a bug in the My Devices section of the UI.
If you change the icon for one device, save & go back, when you select another device and, for example, change its device name, when you save & go back you discover that the icon has changed to the one that you set for the previous device.  You then have to select the second device again and change its icon back to what it was.
1 REPLY 1
bobpullen
Fixes: 331
Re: Hub Two settings bug
@Talldave - thanks for reporting. Anyone else able to replicate this behaviour? I don't have easy access to a Hub Two at the moment.
Edit: this sounds similar.
