Hub Two is a backward step
NeptuneReds1
Just upgraded to the Plusnet Hub Two router and it is seems to be a backward step due to the following:
1) The customer service technical team seem to lack training/knowledge of the new router and help is limited. The guy I spoke to said his team haven't even seen the router yet and there is no direct access portal for them to use to help customer with queries.
2) It seems that it is no longer possible to disable SSID broadcast from the router. This was possible in Hub One. I connect the router to a separate wireless mesh system (Deco) and would prefer to switch off the Plusnet SSID.
3) For other customers (as I don't need to do this) it seems that it is no longer possible to split the wireless bands 2.4 and 5 GHz as separate SSIDs.
Can anyone offer any further insights? Otherwise I'm sticking with Hub One and hope Plusnet improve the above.
Thanks.
12 REPLIES 12
Fixes: 1,495
Re: Hub Two is a backward step
Moderators Note
This topic has been moved from Fibre to My Router
@NeptuneReds1
For me the Hub Two is an improvement, I use mine in 'Bridge Mode' which allows me to use my own router and take advantage of it's features.
Does your deco devices have a built in router which is able to make PPPoE connection?
As to splitting the 2.4 and 5Ghz signals there should really be no need to but in practice is seems to be requirement for some, but not me.
Fixes: 480
@NeptuneReds1
You are quite right, you cannot split the bands on the Hub 2. Otherwise the wireless is better. This is the same as the BT Smarthub 2.
It is unlikely to be changed so if you can explain your problem then maybe we can suggest work around solutions.
bobpullen
Fixes: 331
Colour me confused Huh
All staff are entitled to a Hub Two at no cost assuming they're using the broadband perk that comes with employment.
Regardless, support staff still have access to an emulator and can also access elements of the router remotely to view things like home network topology etc. There's also a bunch of Help & Support content and videos that are publicly available.
Oh, everybody was trained too Wink
Both the 2.4GHz and 5GHz radio can be disabled which will disable the default SSID(s) from broadcasting. There is however a bug in the current firmware that results in hidden backhaul SSID's continuing to broadcast when this is done. They are not 'visible' via the usual methods and certainly shouldn't noticably interfere with the operation of the Deco equipment.
Should be fixed in a future firmware.
As others have alluded to: not possible.
I don't suppose it makes a huge amount of difference in your situation as you're not relying on the Plusnet hub's Wi-Fi. It is a more capable device with more memory/faster processor and some features the Hub One doesn't permit (custom DNS/allowing ping responses on the WAN interface/bridge mode etc.) but again, if none of this is of interest to you, then the difference is negligible.
Should you decide not to use the Hub Two then it would be helpful if you could send it back to us.
NeptuneReds1
“ For me the Hub Two is an improvement, I use mine in 'Bridge Mode' which allows me to use my own router and take advantage of it's features.
Does your deco devices have a built in router which is able to make PPPoE connection? ”
Thanks for your reply. Unfortunately the Deco device doesn’t support this but thanks for the helpful suggestion.
NeptuneReds1
“1) The customer service technical team seem to lack training/knowledge of the new router and help is limited. The guy I spoke to said his team haven't even seen the router yet and there is no direct access portal for them to use to help customer with queries.
Oh, everybody was trained too Wink”
- thanks for your reply, that is reassuring to know but it seems the CSC agent I spoke to today did not have any knowledge of the tools and training you suggest is available and from what he said it seemed to be a wider issue among colleagues i.e he was asking me to relay what I could see in the admin portal and would then check with his manager to discuss options etc. I have an open ticket and I’m happy to pass on details if you can get in touch with me privately.
Good to know the SSID broadcasting bug will be fixed in a future firmware release. I did discover this myself and noticed this issue too. Is there a date for the release please?
NeptuneReds1
Further to my last post. If you work for Plusnet and want to get in touch, you may be able listen back to my call with the agent to hear for yourself about the issue I reported.
LaurenB
Fixes: 131
Thanks for getting in touch @NeptuneReds1, I have passed on some feedback internally with regards to the agent you spoke to just so this can be reviewed and help them going forward.
Thanks for providing the feedback Smiley
 Lauren Barry
RichardB
Seasoned Champion
Fixes: 39
Having setup DECOs for others I can say that DECOs do support PPPoE.
Set the DECO up in router mode and not Access point mode.
Set the Hub two to bridge mode.
Regards
Richard
bobpullen
Fixes: 331
@NeptuneReds1 no date for the release. We're about to embark on an update shortly and I'm afraid it hasn't made the cut this time round Sad
DerekW
I personally found the hub 2 and it's settings a bit to basic for my needs so once the line test period was over I switched it out with my TP Link Archer router
"No one has ever become poor by giving" - Anne Frank
John33
What would be advantages of your other router?
