Getting port forwarding to work on Hub 2
buttimer
Hi, I had port-forwarding working fine on my Hub 1, but cannot get the port to open on Hub2.
I've attached a screenshot of the rule that I created in the firewall section of the router webpage.   I have checked my Plusnet account and the firewall there is off.  What can cause the port to remain closed ? (using https://www.yougetsignal.com/tools/open-ports/ to check port  status)  Any helpwould be greatly appreciated !
6 REPLIES 6
bobpullen
Fixes: 331
Re: Getting port forwarding to work on Hub 2
Is 192.168.1.99 still the local address of the Arduino testrig, or has it changed?
Can you access the internal IP on port 84 when connected to the local network?
How are you trying to access the resource remotely?
buttimer
Hello Bob, yes, I can access 192.168.1.99:84 locally. I am accessing remotely via NoIP (but have just thought that I SHOULD try my public address port 84 to see if that works !!)
buttimer
Bob, public IP address:84 works OK.  Just thought, I seem to rmember having to tell the router that I was using NoIP so that it was informed of a public address change - will go hunting .... !!
buttimer
OK - found DDNS on the Hub2 and it is OFF - That's my problem !!! MANY thanks for making me think !!
buttimer
All working now  !!  Thank you again !
bobpullen
Fixes: 331
Glad all is now well Smiley
