Hub Two & TP Deco(M4 & M5)
mbl
Hi all,
I'm new to the Forum so apologies for the dumb questions in advance!
I've got the Hub Two and have a TP Deco(M4 & M5) Mesh network running.  The Deco is currently running in access point mode, and I've turned off wifi on the Hub Two.  I want to use the TP Deco as a Router rather than AP and wondered if anyone knew what settings I need to apply in the Hub Two in order for this to work, and if the LAN cable moves from the standard ports to WAN if I do this?
Thank you Smiley
5 REPLIES 5
Fixes: 585
Re: Hub Two & TP Deco(M4 & M5)
Question one , what PlusNet product do you have , Unlimited Fibre(or Extra) (FTTC) or Full Fibre (FTTP) ?
If you have Full fibre, then you don't need the HUb 2 at all, simply connect the Deco to the ONT.
If FTTC then change the Hub 2 to bridge mode, connect a LAN port to the Deco.
Either way , you then configure the Deco (in router mode) internet connection for PPPoE and enter your Plusnet username (suffixed with @plusdsl.net and your account password.
As indicated above, the cable does not move. The WAN port on the Hub 2 is ONLY used to connect to a modem or ONT
@mbl I see you've raised this question twice, was this intentional as it is against forum rules to cross post.
You need to the set the Hub Two into 'bridge mode'
This is achieved by navigating to Advanced Settings >Broadband >Internet. Switch is at the bottom of the screen
The Deco can the be configured as a router, Select PPPoE with you broadband username and password. NO VLAN required
Hub LAN 1 2 or 3 to the port to port assigned as WAN on the deco.
HTH
mbl
Thank you!  It's Unlimited Fibre Extra. I'll go and try that.
mbl
Thank you - yes, sorry about that, I did try and delete the other post Sad
Hopefully a friendly moderator will close/remove it.
