Unable to connect to Internet using Deco X60
DeathRoll666
Hi all, would anyone have an idea on why I can't connect to the internet while using Tp-Link Deco X60?? I've tried to connect it straight to the wall socket, I've tried to connect it through Hub 2 in Bridge Mode. Just to add, while I was setting network on Deco X60 I've set it up as pppoe and used my credentials for it to log in.
My hub 2 connects to the internet straight away to compare.
I'd like to know if there's any solution before I return Deco.
13 REPLIES 13
Fixes: 480
Re: Unable to connect to Internet using Deco X60
@DeathRoll666
Which settings did you use? VLAN should be left blank. Use the ones for connecting to an Openreach modem here:  https://www.plus.net/help/broadband/broadband-connection-settings/
DeathRoll666
Hi I've used those settings as there stated when connecting with openreach modem. Hub 2 was in Bridge Mode (pink led lights) connected Deco to 1st port in Hub 2, used those settings and Deco could not establish internet connection
Mustrum
Fixes: 81
@DeathRoll666    you mention openreach modem, do you mean the ONT? Are you on full fibre?
If not and assuming you just meant the settings when connected to an openreach modem, then username and passord  are the only other suspects? Are you using the rigt ones?
DeathRoll666
Yes I'm on full fibre 500mbps and I have no clue on how to make Deco connect to internet
Mustrum
Fixes: 81
Ok, then you don't need the Hub 2, just plug the Deco into the ONT and use the right settings.
DeathRoll666
That's how I connected the Deco. One end of Ethernet cable plugged in into port in the Ont box, other end into 1st port in Deco. While setting up Deco I've chosen pppoe , entered my username and password. Can't connect to internet....
Browni
Aspiring Hero
Fixes: 61
Are you using [email protected] for the username in the Deco?
DeathRoll666
Sure thing I'm using [email protected].
Fixes: 480
I first mentioned Openreach modem as the settings are the same for a Full Fibre connection. There is no Full Fibre option and if you try the FTTC 'Fibre' option then this includes setting VLAN, which can screw things up.
Fixes: 480
@DeathRoll666
Have you tried using the same username (less the @plusdsl.net bit) and password to log into your Plusnet account? This is a good way to check that you have copied it correctly.
Frosty2235
Did you get this to work?
I'm trying to connect my X60, but running in to the same issues. I've tried...
[email protected], username only and included password.
PPPoE Always On is active and settlings match those of the Hub 2, which connects fine.
DeathRoll666
Hi, info i was not able to get this working. I've already returned Deco to Amazon and got my money back
Frosty2235
Solved!
Prior to switching to Plusnet I was with Sky, which used their own hub, which connected directly to the BT openreach double socket.
There was no need for the openreach modem so in this case I was trying to connect the X60 without the modem. I reconnected the modem and it connected straight away.
I forgot that the Deco X60 doesn't come with a built-in modem...DOH
So.....DSL cable from the wall > DSL modem > Deco X60 > Internet 😁👍
