Hub Two Bridge Mode and firmware updates query
bill888
Champion
Fixes: 40
@bobpullen
If a Hub Two is operating in bridge mode, will it continue to receive firmware updates?
I vaguely recall over a decade ago when BT Business division used to offer 2wire made 2700HGV ADSL modem router, they were somehow still able to use TR069 to push firmware updates to these routers when operating in bridge mode.  I recall a firmware update for the 2700HGV broke bridge mode, and there was no fix, so affected business customers had to install replacement modems, me included.
6 REPLIES 6
bobpullen
Fixes: 330
Re: Hub Two Bridge Mode and firmware updates query
I don't think the TR069 client is running when in bridge mode. Assuming it isn't, then the hub wouldn't receive updates. I'll double check when I next get the opportunity though.
@bobpullen
checking the Hub Two TR69 logs there has been no CWMP activity since I configured to 'Bridge Mode'
As expected the Date/Time starts at Oct 01 00:00 on startup, pity there is no way of correcting this.
So the question is are we missing an important update when in Bridge Mode?
Dan.
Fixes: 585
the Hub 2 in modem mode has no IP connection  , that is only present on the connected router that makes the PPPoE connection. AFAICS even if the CWMP client was running it would have no ability to connect to the ACS server.
Well the log file suggests CWMP is not running, as stated there are not entries in the log file.
What would be nice is the ability to set the date/time to be correct.
greygit
"the Hub 2 in modem mode has no IP connection"
I thought a locally connected device would have a connection of some sort. Network protocols don't have to be routable.
And why isn't there an option to download new software and locally 'flash'/update the what passes for WROM nowadays?
greygit
"I don't think the TR069 client is running when in bridge mode. Assuming it isn't, then the hub wouldn't receive updates. I'll double check when I next get the opportunity though."
That would be nice, when and if.
