Hub One firmware update request
D-Parkes
Hi I've just re-installed my Plusnet Hub One router having been using a TP-Link router for a few years.
My Hub One is showing...
Plusnet Hub One | Software version 4.7.5.1.83.8.226 | Last updated 12/10/16
I would like to get it updated please.
From previous posts I see I will need to PM a member of the support team with
- The username of my account
- The serial number of the router
- The MAC address on the router (only first 6 characters are needed)
and factory reset once it has been added to the system.
Thanks in anticipation..
Tags (2)
5 REPLIES 5
Anoush
Aspiring Hero
Fixes: 139
Re: Hub One firmware update request
Welcome to our community forums @D-Parkes
As far as I’m aware, unfortunately we won’t be able to update your router, due to how old the firmware is. Sad
Taken from the post Here if a Hub One is running a firmware version older than 4.7.5.1.83.8.259.1.1, we’d have to look at options to replace the router, if you need the router running the latest firmware.
Are you having any issues with the router?
This is my personal Community Forum account to help out around these parts while I'm at home. If I'm posting from the 1st March 2020, this means I'm off-duty with no access to internal systems.
D-Parkes
Hi Anoush, thanks for the update. My Hub One started to drop broadband access quite frequently. I tried to get a firmware update at the time but never managed to get one so I changed to a TP-Link router which has been very stable and I have been able to download firmware updates for it.
When I read on the community support forums that it was possible to get an upgrade I thought I would give it a try as the Hub One has Gigabit ethernet ports and the TP-Link has only 100Mbit and if I ever have problems with my broadband I would want to restore the Hub One as my broadband modem to simplify support.
I'm reluctant to leave the Hub One as my Firewall without a firmware upgrade as I would expect the old firmware to have a number of security flaws so if I can't get it upgraded I will have to go back to the TP-Link router.
Cheers Dave
Fixes: 1,664
Hi Dave, thanks for getting back to me.
Ah makes sense, no problem I'll be happy to arrange to send you another Hub One free of charge to replace the one you've got, however it might be worth calling our Customer Options Team on 0800 013 2632 as they may be able to post a Hub Two out to you, depending on your contract etc.
If you'd like me to order a replacement Hub One and/or Customer Options can't send you a Hub Two, let me know. Smiley
D-Parkes
Thanks Gandalf, I called the Customer Options Team and talked to [CSA Removed]. I can get a Hub Two when I renew in a few months time and in the meantime he has sent out a replacement Hub One. Great service!
Cheers Dave
Moderator's note by Dick (Strat): CSA name(s) removed (to an area staff can see) as per Forum rules.
Fixes: 1,664
Awesome, sounds like a plan Dave!
Cheers
