Hub One Firmware Updates
FIXED- Subscribe to RSS Feed
- My Router
- Re: Hub One Firmware Updates
19-11-2017 5:34 AM - edited 19-11-2017 5:47 AM
What is the latest firmware for hub one?
Router settings doesn't show firmware information.. have the technical side removed this now?
Picture enclosed
19-11-2017 8:04 AM
Router settings do show you this as I can see them at the bottom of your picture needs enlarging to see it but it clearly is there.
Plusnet Hub One | Software version 4.7.5.1.83.8.237.2.2 | Last updated 19/07/17
19-11-2017 12:57 PM - edited 19-11-2017 12:58 PM
Anyone know what is the latest firmware?
19-11-2017 3:08 PM
@Manny7860 According to Bob Pullen in another thread......
"Firmware/software version 4.7.5.1.83.8.237.2.2
This is the most recent firmware iteration."
So you've got it.
19-11-2017 3:14 PM - edited 19-11-2017 3:14 PM
20-11-2017 8:00 PM
@bobpullen Hi bob, I did PM you but just in case you didn't see. I checked my firmware and my hub one is still on 4.7.5.1.83.8.217.1.1 What do I need to do to get it updated? I've reset with a paperclip twice now and it still doesn't update. I'm not sure if I'm registered on your end?
23-11-2017 7:49 PM
have a look at your tr069 logs on the troubleshooting/event log tab
might show what is going on
26-11-2017 9:21 AM
Thank you. I've had a look, buuuuut what does it mean???
20:54:06, 25 Nov. | (596919.170000) CWMP: Initializing transaction for event code 2 PERIODIC |
20:54:06, 25 Nov. | (596919.160000) CWMP: Initializing transaction for event code 2 PERIODIC |
17:14:22, 25 Nov. | (583736.060000) CWMP: session closed due to error: Could not resolve host |
17:14:22, 25 Nov. | (583736.000000) CWMP: Server URL: https://ceased.tr69.p; Connecting as user: ACS username |
17:14:22, 25 Nov. | (583735.990000) CWMP: Session start now. Event code(s): '6 CONNECTION REQUEST,0 BOOTSTRAP,7 TRANSFER COMPLETE,M Download,4 VALUE CHANGE,2 PERIODIC' |
26-11-2017 10:33 AM
if you are really bored https://www.broadband-forum.org/technical/download/TR-069_Amendment-2.pdf
but i think it maybe that the firmware is there ready to go, will need a reboot i think although i think that should have been automagic
having said that https://ceased.tr69.p; looks wrong to me, in fact https://community.plus.net/t5/My-Router/TR069-events/td-p/1434031 is a discussion of this
@Gandalf so plusnet needs to get on the case i think?
26-11-2017 6:16 PM
Ah yes, I see from that forum thread others with the same problem. And on this thread too. When an account is terminated, PlusNet also remove the Hub's serial number from the management system. So it changes the url to the ceased one. My router is not originally mine. And so would need to be linked to my account I think.
If a lovely person such as @Gandalf or @bobpullen could be so kind?
26-11-2017 6:46 PM - edited 26-11-2017 8:50 PM
26-11-2017 9:05 PM
Sent. Thank you.
26-11-2017 9:07 PM
27-11-2017 12:01 PM
Thanks for confirming the latest software version.
I suggest that one of the PlusNet fixed messages in the My Router forum could be a short note detailing for each extant PlusNet Router the latest software version; when it was issued; and how to obtain should the router not have updated. I hope it wouldn't have to change too often and suspect it would have shortened this thread considerably.
27-11-2017 1:22 PM
i'd also like to see proper release notes on releases
- My Router
