Hub One - 5GHz WiFi issue
DrWinstonOBoogi
Re: Hub One - 5GHz WiFi issue
Hi @bobpullen, could you forward the 273 FW to my router also please?  Tried renaming 5GHz and disabled it, changed lease to 21 days, still getting multiple daily connected no internet and sudden wifi drop outs on 2.4. Fine with cabled connections. Having to reset router to get working for a while.....been happening since we moved to P/N in Dec
Kind Regards, Jon
joethomasld
Hi @bobpullen are you able to push the firmware to our router as soon as you can too. Wifi drops/the router not copping seem too common at the moment and wether or not it is a firmware problem I'm not too sure. Cheers in advance! 🙂
bobpullen
Fixes: 330
@Wrightyp @Leapy @sjblore @DrWinstonOBoogi & @joethomasld - an update has been pushed to your devices. You'll need to switch your routers off/back on to install it.
@rshill1973 wrote:
Hi @bobpullen version still displays as .263
It will do until you reboot 😉
Leapy
Seasoned Champion
@bobpullen Thank you Thumbs_Up
DrWinstonOBoogi
     Updated  @bobpullen Thank you Thumbs_Up  Will report back if it does the trick!
markrichardson
@bobpullen Could you provide me with the updated firmware? The 5g issue has just cost us about £20 due to additional mobile data charges as my wife didn't realise that the WiFi wasn't working.
lukesayers
annamariamuller
@bobpullenCould you please also provide me with the firmware update? Thank you!
bobpullen
Fixes: 330
@markrichardson @lukesayers & @annamariamuller - that's been done for you. You'll need to reboot to apply the update.
@simoncrnfrth - how are things on the .280 firmware? Still no Wi-Fi failures?
bobpullen
Fixes: 330
I am looking for somebody who specifically meets the criteria below that wouldn't mind testing an early firmware for me:-
  • Had 5GHz connectivity problems with .263 firmware
  • Was upgraded to .273 firmware and problems went away
  • Has been running .273 firmware for at least 3-4 weeks
It would involve upgrading you to a new firmware build and leaving the router running for a few weeks to see if the 5GHz Wi-Fi issue returns. If it does then I can easily downgrade you back to the previous build on request. It's worth me mentioning though, that a downgrade will result in a factory reset.
If anybody is interested in helping out, then please drop me a private message. Looking for a couple of people ideally. Thanks.
Edit: I now have a couple of candidates who've kindly offered to help (thanks guys!), so I no longer need anybody to respond to this.
AndyinBrum
can do that Bob, not having to wfh till September so that gives a bit of space to see whether the new update is working
goldfishes
Hi @bobpullen
I have been experiencing problems as described. This seems to happen when either I or my husband connect to our work VPN. Usually one of us 'wins' (i.e. the laptop stays connected) while other devices in the house (the other person's laptop, both our phones and the tab and /or tv, if in use) get 'Not connected to the internet'. The problem was intermittent, but now is happening 2-3 times per day on average. For the most part, hitting the reset button on the router seems to fix it, but this is not always practical.
 My router config footer: Plusnet Hub One | Software version 4.7.5.1.83.8.263 | Last updated 23/06/19
How do I go about getting you to push out the firmware update?
markrichardson
Thanks @bobpullen
Installed and working now... Fingers crossed!
annamariamuller
@bobpullen Thank you so much for the FW update! The Hub states "Plusnet Hub One | Software version 4.7.5.1.83.8.273 | Last updated 27/07/20" — however, the issue persists after reboot of the Hub and my computer.
Do I need to factory reset to benefit from the FW change? Please advise — thank you!
bobpullen
Fixes: 330
@AndyinBrum thanks! I'll drop you a message with further detail.
@goldfishes that's been done for you, you'll need to power off/back-on to apply the update. That said, your symptoms sound slightly different in that this probably is normally persistent until the device is rebooted. The VPN trigger also makes me a bit suspicious.
@annamariamuller you shouldn't need to factory reset but if you're still struggling then it would be a sensible next step. I'd also suggest deleting all of the saved Plusnet Wi-Fi networks from your Mac and re-entering your password etc. for each once the device has been reset.
