Hub One - 5GHz WiFi issue
BigTedh
Re: Hub One - 5GHz WiFi issue
Thank you for your help with this and notifying me that the router is ready for a reboot.. I've now rebooted and will see how the WiFi fares over the coming days/weeks. Hopefully all will be fine.
Shmeker
@bobpulen,
Thanks for the firmware update. Fingers crossed would solve the problem.
mindmagic
@bobpullen Thanks.
globey
Thanks @bobpullen, I'll give that a go.
Since disabling 5GHz, while it has been noticeably slower, I've had no issues with my Chromecast dropping off the network and (it may be coincidence but..) no "Watchdog reset" reboots for 3 weeks (the longest since it started to happen in February) - previously I'd be getting them every few days.
lloydbayliss
Thanks @bobpullen ,
Router rebooted and firmware now showing as .273.
I've re-enabled the 5ghz side and my phone immediately connected to it.  Fingers crossed we're up and away!
Thanks very much for all you've done 👍
Lloyd
rkhazelwood
@maddan69 Picking up a BT HH6 tomorrow, brand new. How do I configure it to connect to PN?
Chappers2000
Thank you @bobpullen . I can confirm my router has received the update and so far so good.
Routefinder
NZWZ10
@bobpullen I have had this issue with my 5GHz wifi for as long as i can remember. Can you please push the .273 firmware update to my router?
kmmfc
@bobpullen Thanks for pushing the firmware version 273 to my router. It’s been rebooted and showing the update so will keep an eye on it and report back any further issues. Thanks again.
garyrwilson68
Thanks @bobpullen, rebooted, at .273 and 5ghz switched back on.
j-d-b
Hi, I'm having problems keeping a stable 5ghz connection to my new laptop, I usually get 38mbs but often only shows at 1.5mbs. Other devices seem fine on 2.4ghz. I understand a firmware update may help?
I am currently running Plusnet Hub One | Software version 4.7.5.1.83.8.263 | Last updated 12/03/19.
I f someone from Plusnet could respond I would be grateful. Thank you.
rkhazelwood
@Routefinder Thank you for the link
rkhazelwood
@Routefinder the instructions in the link are great. However, do I use the password I use to access this forum and my PN account (it's been changed many times) or the original one I used back in the day when I got the PN hub?
Routefinder
@rkhazelwood
AFAIK it is always (I am not aware of any exceptions?) the same password you have used when setting up your previous PN supplied Hub.
HTH
