Hub 2 router
JillF
Hub 2 router
Have just installed my new Hub 2 router.  Then I have been sent a message with Broadband user name.  It says enter it into the router.... how do I do that?
4 REPLIES 4
Fixes: 392
Re: Hub 2 router
@JillF Welcome to the forums. I don't have the Hub2, but someone kindly sent me some screenshots of the settings, so try this.
Navigate to the screen shown below - you will have to login to the Hub to do this, then enter your username ([email protected]) and the password that goes with it - if there is a 'save' option, click that, if not, just exit the Hub and it should save it for you.
3.Hub2 broadband.pngAny problems, come back and say, and I might be able to point someone with more knowledge your way.
bobpullen
Fixes: 331
Re: Hub 2 router
You shouldn't have to manually alter any settings. If we sent you the Hub Two, then it should automatically configure itself within 5 mins or so of being connected to your broadband line.
Fixes: 392
Re: Hub 2 router
I thought it was strange, Bob, but the lady asked, so I replied - next time, I'll keep quiet. 😉
adam945
Fixes: 113
Re: Hub 2 router
It looks like your router is now configured correctly with your username @JillF
Let me know if you have any further issues at all. Smiley
 Adam
 Plusnet Help Team - Leeds
