Hub 2 router, full fibre 900mbps and powerline adapter but uner 100mbps
samk2310
I have recently upgraded to 900mbpa full fibre and purchased tplink WPA8631P kit.
I've plugged one directly into the wall and connect ethernet to the hub 2.
The other upstairs and wired my ps5 to it, I'm only getting speeds of 50mbps on the 5g wifi and also wired ps5 connected to the other powerline adapter.
What am I doing wrong as this should surely get much better speeds?
It's also saying the router isn't one mesh compatible, is this the case with the hub 2?
2 REPLIES 2
Fixes: 466
Re: Hub 2 router, full fibre 900mbps and powerline adapter but uner 100mbps
@samk2310
 The Hub 2 is not mesh compatible.
Regarding Powerline performance, see here.  https://community.plus.net/t5/Tech-Help-Software-Hardware-etc/Powerline-Unit-Performance/m-p/1607450...
Running  a CAT5e cable upstairs is the best way to get full performance.
Fixes: 139
@samk2310
To expand on The Hub 2 is not mesh compatible.
One Mesh is a proprietary mesh system by TP-Link so you need a TP-Link router which supports One Mesh.
Edit:- are you using cat5e (8 wires/4 pairs) or above cables both ends for the powerline network connections?
