Hub 2 as AP - flashing orange light?
Teece
I'm looking to use a spare Hub 2 as a wireless AP. Easy enough to do in the web UI, except that even though I've turned the light off, it's still flashing orange (because there's no internet connection).
Any ideas?
6 REPLIES 6
bobpullen
Fixes: 331
Re: Hub 2 as AP - flashing orange light?
This is by design I believe.
Any perceived error condition will override the light on/off settings.
I'm more curious as to how you have a 'spare' Hub Two TBH? Huh
Teece
I have just upgraded my FTTP trial to proper FTTP, and I'm using my own router. I was offered a Hub 2, since I was accepting a new contract, which I accepted - always useful to have a spare, capable router, in case of hardware failure.
Fixes: 118
@Teece
Black tape rules!!!
Teece
On a white router! 😭😭😭
Fixes: 392
@Teece - why not use white tape, then? 😀
Fixes: 118
@Teece
You could go posh (and expensive) and get some (white) LightDims from Amazon.
