How to open up port 3306 in Plusnet Hub 2
PaulFreeland
Hello
I have just had full fibre installed and it's working well, except I now need to access remote MySQL databases directly, using port 3306, and it is blocked.
The database client software is returning:
Access denied for user 'root'@' [Removed].plus.com' (using password: YES)
[Removed].plus.com is not the server I am trying to connect to. I assume this is a Plusnet firewall blocking the connection.
Moderators Note: Personal information removed
Can anyone advise how to do this in the hub control panel?
Thanks!
Tags (3)
7 REPLIES 7
Fixes: 1,495
Re: How to open up port 3306 in Plusnet Hub 2
the XXXX.plus.com is the identifier of your home connection.
If you need to access a DB running on your home network you need to set up port forwarding in your router.
This can be configured here http://192.168.1.254/firewall.htm in the Hub2.
PaulFreeland
Thank you
I am trying to access a remote MySQL database. i.e. it's an outgoing connection.
For example this is my terminal command:
mysql -uroot -p -h myremoteserver.co.uk
This prompts for the password and then show this error message:
It seems as though myremoteserver.co.uk is being redirected to my home connection identifier which I assume is being done by the router (?)
The router firewall is set to Default - allow all outgoing connections
Can you advise please?
Fixes: 1,495
It's blocked at your remote end, the message is saying your ip address / host is blocked.
You will need to allow access on the remote server.
PaulFreeland
Thank you very much, granting access to my new IP sorted it.
In my defence the error message is very confusing 🙂
Fixes: 1,495
Glad it's sorted for you Smiley
Fixes: 583
I hope access isn't really granted on a specific IP basis. Unless you have opted for a static IP, then there is a possibility you may be allocated a different IP should the connection ever be reset e.g by Openreach maintenance or a router reboot
Fixes: 1,495
judging by the host name returned by the access denied message, I'd say it was static.
