Hub 2 router
petlew
Hub 2 router
May seem a daft question for some, but I’m not at home to look; does the P/n Hub 2 router have a phone port as the BT version does?. And with a digital phone and fibre to the box will this future proof against the “great BT switch off”.
1 REPLY 1
Fixes: 585
Re: Hub 2 router
No, well yes it has a port but it's not enabled in the firmware, so can't be used
