How do i change my plusnet wifi password why is there not an option in this app to do this
rabbydaddy71
Hello
Tags (1)
3 REPLIES 3
mrjkenward
Re: How do i change my plusnet wifi password why is there not an option in this app to do this
This is usually something you do on the router. Get into it with a web browser and the graphical user interface (GUI).
@rabbydaddy71
Assuming you have a Hub Two?
You will find help here https://www.plus.net/help/broadband/router-user-guides/hub-two/
Fixes: 480
@rabbydaddy71
What App?
The replies that you are receiving are referring to the wireless password.
However, some people mistakenly refer to their broadband connection as 'their WiFi'. If this is the case here you need to log  in to your Plusnet Account and change it. After doing this you need to switch your hub off for a minute or two then restart it.
