Homehub 5
- My Router
- Homehub 5
Homehub 5
Homehub 5
13-07-2016 6:09 PM - edited 13-07-2016 6:12 PM
Just bought a HH5 from a mate. I was under the impression that it was a B, but it turns out its an A.
When using the BT Modem, my BRAS rate was approx 74mbps, but with this new router I am syncing at 66.87, which equates to a BRAS of approx 64mbps. Is this due to G.INP and the Hub A not fully supporting it? I am on a 40/20 package, and will be moved to 55/10, so its not much of a biggie, but just wondered why
its on firmware BT Home Hub 5 (Type A) | Software version 4.7.5.1.83.8.204.1.11 | Last updated 18/09/15
Re: Homehub 5
Re: Homehub 5
13-07-2016 7:43 PM - edited 13-07-2016 7:58 PM
I could be wrong, but i don't think G.INP is the issue. I thought BT Openreach disabled G.INP on upstream on all cabs, to ensure compatibility with modems which did have issues, such as ECI modem and HH5 Type A - both use Lantiq SoC.
Which Openreach modem do you own? Huawei or ECI ?
Re: Homehub 5
Re: Homehub 5
13-07-2016 7:48 PM
Thanks.
Up until today, I was using an ECI modem, paired with a TG582n. Its an ECI Model B. I am however connected to an Huawei Cab. Been connected for nearly 18months, with no issues.
I wonder if a member of the team could see if I have G.INP actually enabled on my Cab or line
Re: Homehub 5
Re: Homehub 5
13-07-2016 7:53 PM
Re: Homehub 5
Re: Homehub 5
13-07-2016 8:01 PM - edited 13-07-2016 8:08 PM
fwiw, I use an ECI modem connected to Huawei cabinet at 58 mbps.
I have two used HH5A and a new Plusnet Hub One, all three report IP profile between 0-2 mbps less than the ECI.
Re: Homehub 5
Re: Homehub 5
14-07-2016 6:50 PM
Well interestingly enough, it appears the hub resynced at around 6am this morning, now at 78 down 19 up.
Would be interested if a member of the plusnet team could post up my line settings.
