High Ping Wifi
mcfc482
High Ping Wifi
i recently got plusnet broadband and the speed has been up and down but useable. When i try to play with my ps5 online the ping is ridiculously high over wifi. I am basically sat right next to the router so not sure why this is happening.
i had sky broadband before and the ping was fine over wifi.
Hopefully someone can help.
thanks
9 REPLIES 9
Fixes: 1,485
Re: High Ping Wifi
to be honest if your ps5 is next to the router you should use an ethernet cable, it's always better for gaming.
Fixes: 1,485
Re: High Ping Wifi
Moderators Note
This topic has been moved from ADSL Broadband to My Router
mcfc482
Re: High Ping Wifi
I shouldn’t have 1000 ping when trying to play through wifi though.
i want to ensure this isn’t a deeper problem and if i needed to play via Wi-Fi there wouldn’t an an issue.
Fixes: 1,485
Re: High Ping Wifi
WiFi can be impacted by many things though and you wouldn't notice that for things that don't need low latency, such as streaming / browsing.
Try playing wired and see if you hit the same issue, if you do then there may be a routing / line issue.
If you don't then there's probably trouble shooting steps for the wifi - e.g. if you have a hub one you can try splitting the wifi bands.
mcfc482
Re: High Ping Wifi
Model on bottom of router is 2704N, is that a hub one?
Fixes: 1,485
Re: High Ping Wifi
No, that's a hub zero.
so assuming you're on ADSL and not fibre?
mcfc482
Re: High Ping Wifi
Yeah ADSL, wired is fine although ping is a bit worse than when i had Sky Broadband.
I have a suspicion the poor wireless ping is due to a low quality router?
Fixes: 1,485
Re: High Ping Wifi
it's not the greatest router in the world and is pretty old.
mcfc482
Re: High Ping Wifi
Trying with an old BT router to see if it makes a difference.
