High Ping Wifi
- My Router
- Re: High Ping Wifi
High Ping Wifi
19-03-2021 1:44 PM
i recently got plusnet broadband and the speed has been up and down but useable. When i try to play with my ps5 online the ping is ridiculously high over wifi. I am basically sat right next to the router so not sure why this is happening.
i had sky broadband before and the ping was fine over wifi.
Hopefully someone can help.
thanks
Re: High Ping Wifi
19-03-2021 3:08 PM
Re: High Ping Wifi
19-03-2021 3:09 PM
Moderators Note
This topic has been moved from ADSL Broadband to My Router
Re: High Ping Wifi
19-03-2021 3:55 PM
I shouldn’t have 1000 ping when trying to play through wifi though.
i want to ensure this isn’t a deeper problem and if i needed to play via Wi-Fi there wouldn’t an an issue.
Re: High Ping Wifi
19-03-2021 4:13 PM
Try playing wired and see if you hit the same issue, if you do then there may be a routing / line issue.
If you don't then there's probably trouble shooting steps for the wifi - e.g. if you have a hub one you can try splitting the wifi bands.
Re: High Ping Wifi
19-03-2021 4:14 PM
Model on bottom of router is 2704N, is that a hub one?
Re: High Ping Wifi
19-03-2021 4:19 PM
so assuming you're on ADSL and not fibre?
Re: High Ping Wifi
19-03-2021 4:24 PM
Yeah ADSL, wired is fine although ping is a bit worse than when i had Sky Broadband.
I have a suspicion the poor wireless ping is due to a low quality router?
Re: High Ping Wifi
19-03-2021 5:02 PM
Re: High Ping Wifi
19-03-2021 5:47 PM
Trying with an old BT router to see if it makes a difference.
