Help with plusnet router two and google nest wifi
Mejisan
I have had a plusnet one hub for ages, connected WAN to WAN to my google nest wifi which then bounces Internet around the house via a series of Google wifi points (on a mesh network).
Today I got a new plusnet hub (the Two model). Connected everything in exactly the same way (Wan on hub to wan on Google wifi) and it doesn't work.
Google doesn't seem to recieve the Internet from the hub. The Google wifi setup says something about wan connection not working.
Weirdly, if I just plug the ethernet cable into one of the other plusnet hub ports (and other end still in Google wifis wan socket) it gets Internet fine.
Any idea why ? Or how I can fix?
Will Internet be slower this way ?
26 REPLIES 26
Mustrum
Fixes: 81
Re: Help with plusnet router two and google nest wifi
You should be using the Lan pier on the PN hubs.
I think it was a bit of a fluke you got it working on the HUb1.
Mejisan
Hi thanks for your reply. Can you expand a bit on your answer? What's a lan pier and how do I set one up?
Is there be any disadvantaged to having it connected as I do currently (wan on Google wifi to normal ethernet socket on router rather than wan socket)
Mustrum
Fixes: 81
Lan port - it was just a typo.
Wan ports are meant to be import ports, ie they expect a signal in from a modem or similar. So connecting two together makes no sense, I expect the HUb1 admin log would have been full of errors.
pjmarsh
Fixes: 24
@Mustrum, off the top of my heard (and I could be totally misremembering this, so apologies if I'm wrong), but I think on the Hub One, the WAN port could also be a LAN port, possibly depending on configuration.  @bobpullen is the guy to set that straight though.
bobpullen
Fixes: 330
@pjmarsh - you're mistaken. The Hub One has four LAN ports and a dedicated WAN port. I'm at a bit of a loss to explain quite how a WAN > WAN connection was working previously for the OP Huh
pjmarsh
Fixes: 24
Thanks @bobpullen.  It's been a while since I looked at the Hub One
Mustrum
Fixes: 81
@pjmarsh   I suspect you were thinking of a BT HH6, or EE Smart Hub, where the WAN port could be reconfigured, I believe.
Anyway back on topic, @Mejisan  if your Google Nest has the option to connect via PPOE, a better solution would be to use the Smart Hub in modem mode.
Mejisan
Whats the advantage of pppoe over just having it as I have currently (Google wan to plusnet lan) ?
I did try pppoe when I was trying to get wan to wan to work, but it never seemed to accept the login details.
Fixes: 476
You should never have connected WAN to WAN.
Leaving it as you now have it configured leaves the set up double NATing, which can cause problems.
For correct configuration you need to set the Hub 2 to Bridge mode and enter your plusnet log in details in to your mesh router.
Mejisan
Thanks.
For the login details, is it the same login details I use to login to my account on the plusnet website? Do I use the @plusdsl.net adress or my normal email address?
Fixes: 476
@Mejisan
It's your account [email protected]  as in [email protected] and your account password NOT your email address.
Matt15
Hi Baldrick1,
I am having the same issue when connecting the plusnet 2 router to google nest wifi pro.
I have gone onto the admin settings, enabled bridge mode, restarted the router, plugged in the google nest wifi pro and then started the set up on the google app. But each time it says it cannot connect and the plusnet hub 2 is not sending wifi to the google nest wifi pro.
You mentioned:
"For correct configuration you need to set the Hub 2 to Bridge mode and enter your plusnet log in details in to your mesh router." What do you mean by this please?
Thanks!
Matt15
Hi Mejisan,
Have you had any update on if your plusnet hub works with your google wifi? I am having a similar issue with the plusnet hub not connecting to my google nest wifi (pro).
Thanks.
Fixes: 146
When a Hub Two is in bridge mode the WiFi is turned off, you need to make a wired connection between the Hub Two and Google Nest
HTH
