Help with plusnet router two and google nest wifi
Matt15
Re: Help with plusnet router two and google nest wifi
Thanks.
I've got an ethernet cable plugged into the WAN port on the plusnet 2 (the plus net 2 has a pink light) and the ethernet port with a globe icon above, on the google nest wifi (pro). Google can connect to the nest wifi but it says the plusnet 2 isn't giving any wifi to the nest wifi.
Any ideas why that may not be working?
Fixes: 585
Yes, as stated above , you need to connect to one of the LAN ports on the Hub 2 not the WAN port!
Matt15
Hi, thanks. But then it asks me to log in and the ip address. What log in info is needed and where do I find those details please?
It would be handy if someone did a step by step guide on how to connect the google nest wifi and what details are required, so that people don't have to keep asking.
Mejisan
.x.x.x.x.
Matt15
Did you get yours working Mejisan? I get to the step when google nest wifi says that it needs WAN details and asks me to log in and for the ip. I don't know what it means, what details are required etc. The google nest wifi is plugged in via an ethernet cable to one of the ports (not the WAN) on the plusnet 2.
Fixes: 585
The settings you need to use your  own router are here https://www.plus.net/help/broadband/broadband-connection-settings/
You can ignore the vlan I'd settings , the Hub 2bin bridge mode will handle that
Matt15
Hi MisterW,
Thanks,
To be honest, I don't know much about wifi.
What I am asking is that when the google nest wifi tries to connect, it asks to connect the one of the below
What one do I chose and when I chose one, what do I do to connect?
You select PPPoE
https://support.google.com/googlenest/answer/6246630/#PPPoE&zippy=%2Cpppoe
Fixes: 585
and that's why ISPs supply self configuring routers
If you wish to use your own router then you really need to do some research and understand what is necessary to configure them
Matt15
Thanks Dan.
  1. Enter your account name and password. Verify the password, then tap Save .
  2. Reconnect the Ethernet cable to your Wifi point.
Are those details the plusnet log in details?
Matt15
Hi Mister1,
Thanks, I have installed some nest wifis before with virgin media but this is the first time using plusnet.
Fixes: 585
they're the username and password as described in the link to the help pages I posted earlier
