Google Wifi
jelstone
Google Wifi
Hey all,
I have recently setup Google WiFi and disabled the interface on the Technicolor TG582n Router, I have a slight problem where as I cannot access my printer which is on 192.168.86.x network, from my PC on 192.168.1.x.  I have tried adding an IP on the router on the 86 network but it does not bridge the connections.  Is there any way to do this?
Product Name: TG582n
Software Release: 10.2.5.2
Tags (3)
4 REPLIES 4
bill888
Champion
Fixes: 36
Re: Google Wifi
You could try forwarding the ports from PC to printer if you know exactly which ports are required by the printer.
But it would be far easier if you just connect your PC to the LAN port of your Google wifi so it is on the 192.168.86.x subnet.
fwiw, the Google Wifi is a router in itself and is really designed to replace an existing router.  If you are using ADSL, you could reconfigure the TG582n into  'bridge mode', and then configure Google Wifi to use PPPoE to connect to Plusnet.
There are old threads for now to reconfigure TG582n into bridge mode, but I recall they generally recommend using these instructions from Zen when using v10 firmware.  Someone will no doubt correct me if I'm wrong.
https://support.zen.co.uk/kb/Knowledgebase/Broadband-Uploading-templates-to-a-Technicolor-TG582n-rou...
ex-Plusnet (ADSL, FTTC) 2008-2023. now BT (FTTP) 2023-
jelstone
Re: Google Wifi
Thanks bill888,
I decided to bite the bullet and purchase a 16 port switch and add it downstream of the primary WiFi point as per https://support.google.com/wifi/answer/7215624?hl=en&ref_topic=6243113 which all works great apart from one snag - I have a requirement to come inbound from the internet to my 86 network, I figured it would be a lot simpler if I just changed the IP on the TG582n to 86.254 but for some reason Google WiFi didn't like being on the same network, turning off DHCP on the TG582n seemed to knock it out but I couldn't get both to play nice on the same network.  I had to flip it back to 1.254 and enable DHCP again before Google WiFi would connect /confused.
bill888
Champion
Fixes: 36
Re: Google Wifi
The problem you describe is a side effect of 'double NAT'.
https://kb.netgear.com/30186/What-is-Double-NAT?cid=wmt_netgear_organic
See my earlier post about converting your TG582n into a 'bridge modem' if you use ADSL (or perhaps buy a bridge modem).  If you have fibre, remove the TG582n and connect the Google wifi direct to the Openreach VDSL bridge modem.  Configure the Google wifi router to connect using PPPoE, not DHCP.
jelstone
Re: Google Wifi
Thanks bill888, I have gone with the direct PPPoE option - so far so good.
