Fritz Repeater 6000
jaikharbanda
Fritz Repeater 6000
Has anyone reliably connected the Fritz Repeater 6000 to the Plusnet Hub Two?
If so, please share instructions!
4 REPLIES 4
Fixes: 473
Re: Fritz Repeater 6000
@jaikharbanda   Welcome to the Plusnet Community Fora.
My understanding is that this is a mesh satellite, designed to mesh with a Fritz!box router. Not a WiFi repeater. Consequently it is probably not compatible with a Hub 2.
Fixes: 113
@jaikharbanda
You could always get yourself a FritzBox router.
https://uk.webuy.com/search/?stext=fritzbox+routers
Fixes: 145
@jaikharbanda
it might be possible to pair them using WPS
Suggest a search on the topic
Fixes: 145
@jaikharbanda
As quick search for provides these instructions: - Connecting FRITZ Repeater to a router from another manufacturer
The advantage of buying a second hand Fritz router would result in true Mesh network,
EDIT: best to look at a model with WiFi 6
