Own router settings
Ninko
Own router settings
Could someone confirm all these settings are correct for PlusNet full fibre (connected directly to ONT)
5 REPLIES 5
Fixes: 585
Re: Own router settings
@Ninko looks about right to me, as long as there's no VLAN ID set somewhere else
Username should be your Plusnet account name suffixed with @plusdsl.net and the password is the one you use to access the member portal at www.plus.net/login
@MisterW
I'm wonder about the NAT type setting, is Symmetric correct?
Fixes: 585
It shouldn't matter , it's internal to the router
Ninko
I'm not sure what VLAN ID is?
As for the NAT type, I can change it if it's not right?
Fixes: 585
If you don't know what VLAN ID is then you've almost certainly not set it. I only asked because if you read the plus net help for setting up your own router , it mentions using a vlan ID for Fibre. In the case of full fibre , the ONT handles the plan requirement and so the router should not set it.
As for NAT type , I wouldn't worry, most routers don't even have the ability to change it!
